MAX6675 Wrapping Class-based Arduino Libraries
dear friends,
I try to Wrapping Class-based Arduino Libraries for max6675
the code I used is
    // Tell XOD where it could download the library:
    #pragma XOD require "https://github.com/adafruit/MAX6675-library"
    //Include C++ libraries
    {{#global}}
    #include <max6675.h>
    {{/global}}
    struct State {
       uint8_t mem[sizeof(MAX6675)];
    using Type = MAX6675*;
    {{ GENERATED_CODE }}
     static_assert(isValidDigitalPort(constant_input_CS), "must be a valid digital port");
     static_assert(isValidDigitalPort(constant_input_DO), "must be a valid digital port");
     static_assert(isValidDigitalPort(constant_input_CLK), "must be a valid digital port");
    MAX6675 dev =MAX6675 (constant_input_CLK ,constant_input_CS,constant_input_DO);
    void evaluate(Context ctx) {
        auto state = getState(ctx);
        Type sensor = new (state->mem) MAX6675();
            return;
        emitValue<output_Temp>(ctx, sensor->readCelsius());
i got an error like
> Begin compiling code for the board Arduino Mega or Mega 2560 📦
> C:\Users\dell\AppData\Local\Temp\xod_temp_sketchbookdHVhgn\xod_1603659694078_sketch\xod_1603659694078_sketch.ino:
> In instantiation of 'void
> xod::____max6675_device::Node<constant_input_DO, constant_input_CS,
> constant_input_CLK>::evaluate(xod::____max6675_device::Node<constant_input_DO, constant_input_CS, constant_input_CLK>::Context) [with unsigned char
> constant_input_DO = 4; unsigned char constant_input_CS = 5; unsigned
> char constant_input_CLK = 6;
> constant_input_CLK>::Context = xod::____max6675_device::Node<4, 5,
> 6>::ContextObject*]':
> C:\Users\dell\AppData\Local\Temp\xod_temp_sketchbookdHVhgn\xod_1603659694078_sketch\xod_1603659694078_sketch.ino:1599:36:
> required from here
> C:\Users\dell\AppData\Local\Temp\xod_temp_sketchbookdHVhgn\xod_1603659694078_sketch\xod_1603659694078_sketch.ino:1214:23:
> error: no matching function for call to 'MAX6675::MAX6675()'
>                        ^~~~~~~~~~~~~~~~~~~~~~~~~~ In file included from
> C:\Users\dell\AppData\Local\Temp\xod_temp_sketchbookdHVhgn\xod_1603659694078_sketch\xod_1603659694078_sketch.ino:1066:0:
> C:\Users\dell\AppData\Local\Temp\xod_temp_sketchbookdHVhgn\libraries\MAX6675_library/max6675.h:16:3:
> note: candidate: MAX6675::MAX6675(int8_t, int8_t, int8_t)
> MAX6675(int8_t SCLK, int8_t CS, int8_t MISO);    ^~~~~~~
> note:   candidate expects 3 arguments, 0 provided
> C:\Users\dell\AppData\Local\Temp\xod_temp_sketchbookdHVhgn\libraries\MAX6675_library/max6675.h:14:7:
> note: candidate: constexpr MAX6675::MAX6675(const MAX6675&)  class
> MAX6675 {
>        ^~~~~~~ C:\Users\dell\AppData\Local\Temp\xod_temp_sketchbookdHVhgn\libraries\MAX6675_library/max6675.h:14:7:
> note:   candidate expects 1 argument, 0 provided
> note: candidate: constexpr MAX6675::MAX6675(MAX6675&&)
> Error during build: exit status 1 Compilation failed Command Process
> exited with code 1 The generated C++ code contains errors. It can be
> due to a bad node implementation or if your board is not compatible
> with XOD runtime code. The original compiler error message is above.
> Fix C++ errors to continue. If you believe it is a bug, report the
> problem to XOD developers.
It is saying the error is on this line
It wants an argument for the function call at the end.
hi, thanks for your reply, what do you suggest me to do?
I’m not good in c++
Fixing the problem is much harder than finding it in this case… I haven’t done a lot with C++, but that line looks odd to me with new in front of a function call. Sorry I can’t help much more than that.
Hi Ahmed,
Try your luck with this library:
I don’t have a MAX6675, so I haven’t been able to test my library, but it does compile.
I saw that you were using the old style C++ syntax, so I thought it was easier to make a fresh start.
Thank you very much, it is working but have a very small problem in XOD when I use the watch to show the result.
in the serial monitor, there is no problem.
thank you again
