come convertire le libreie arduino per usarle con xod
General information: XOD Documentation — XOD
Conversion-specific information: Wrapping Class-based Arduino Libraries — XOD
Unfortunately, conversion process is NOT trivial. You’ll probably want to start with simpler projects in XOD and work up to this task. Unless you get lucky and can find existing code to copy and use with minimal modification, it is going to require coding in C++
