Converting an Arduino sketch to XOD
Hi All,
I am hoping someone will be able to help me, I have this sketch below that is really useful but don’t know enough of how to convert this to work in XOD.
Is there anyone here that would be able to assist in making this possible?
Unfortunately I am no good at writing code in any capacity and can just get by with XOD.
Any help is always appreciated.
Thank you.
// K40 MotoLift Table Sketch for Arduino nano and A4988 Stepper-Driver
// created by SnakeP
// Version 2.0 BETA (OLED included)
// 31.01.2021
//Benoetigte Bibliotheken (müssen vor dem Compilieren eingebunden werden!)******
#include <Wire.h>
#include <Adafruit_SSD1306.h>
Adafruit_SSD1306 display(4);
// Zuordnung der E/As
#define ENA 2 //Enable
#define STP 3 //Steps
#define DIR 4 //Direction
#define MS1 5 //MS1 an Treiber
#define MS2 6 //MS2 an Treiber
#define MS3 7 //MS3 an Treiber
#define STPD 8 //Endschalter Down
#define UP01 9 //Eingang Aufwaerts 0,1mm
#define UP1 10 //Eingang Aufwaerts 1mm / Dauerbetrieb
#define DOWN01 11 //Eingang Abwaerts 0,1mm
#define DOWN1 12 //Eingang Abwaerts 1mm / Dauerbetrieb
#define COUNTERRESET 13 //Nullenstellen der OLED-Anzeige
bool bUP1 = LOW; //Merker Aufwaerts 1mm aktiv
bool bUP01 = LOW; //Merker Aufwaerts 0,1mm aktiv
bool bDOWN1 = LOW; //Merker Abwaerts 1mm aktiv
bool bDOWN01 = LOW; //Merker Abwaerts 0,1mm aktiv
float poscount = 0; //Merker fuer OLED-Anzeige
float poscount_cont_up = 0;
float poscount_cont_up_mm = 0;
float poscount_cont_down = 0;
float poscount_cont_down_mm = 0;
//Hilfsmerker Zaehler (Diese Kennzahlen individuell befuellen!)
int steps_01 = 20; //Hier ausgemessene Anzahl Steps fuer 0,1mm Fahrt eintragen
int steps_1 = 200; //Hier ausgemessene Anzahl Steps fuer 1mm Fahrt
int stepperspeed_l = 500; //Delay Stepperschritte in Microsekunden (Einstellung Steppergeschwindigkeit) langsame Einzelstep-Fahrt
int stepperspeed_h = 250; //Delay Stepperschritte in Microsekunden (Einstellung Steppergeschwindigkeit) schnelle Dauerfahrt
int dec_continious = 1000; //Delay fuer Start Dauerfahrt
bool bPosHold = LOW; //Dauerhafter Haltestrom fuer Stepper (Positionshaltung) HIGH = ein / LOW = aus
void setup() {
// put your setup code here, to run once:
display.begin(SSD1306_SWITCHCAPVCC, 60);
// Definition der E/As
pinMode(ENA, OUTPUT);
pinMode(STP, OUTPUT);
pinMode(DIR, OUTPUT);
pinMode(MS1, OUTPUT);
pinMode(MS2, OUTPUT);
pinMode(MS3, OUTPUT);
pinMode(UP01, INPUT);
pinMode(UP1, INPUT);
pinMode(DOWN01, INPUT);
pinMode(DOWN1, INPUT);
pinMode(STPD, INPUT);
pinMode(COUNTERRESET, INPUT);
digitalWrite(ENA, HIGH); // Motor Enable (EIN)
//Arbeitsmodus (Microsteps) Einstellung der Treiberstufe (Default 1/8 Step):
digitalWrite(MS1, HIGH); // Einstellung Microsteps A4988:
digitalWrite(MS2, HIGH); // MS1 MS2 MS3
digitalWrite(MS3, LOW); // L L L 1/1 Step
// H L L 1/2 Step
// L H L 1/4 Step
// H H L 1/8 Step
// H H H 1/16 Step
void loop() {
// put your main code here, to run repeatedly:
display.clearDisplay(); //Ansteuerung OLED-Display
display.fillRect(0, 0, 127, 63, WHITE);
display.fillRect(3, 3, 121, 57, BLACK);
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(11, 10);
display.println(“K40 MotoLift-Table”);
display.setCursor(18, 20);
display.setTextSize(2);
display.println (“Position”);
display.setCursor(45, 40);
display.println (poscount, 1);
display.display();
bUP01 = digitalRead(UP01); //Abfrage Eingang UP01, setzen Merker fuer Abarbeitung
bUP1 = digitalRead(UP1); //Abfrage Eingang UP1, setzen Merker fuer Abarbeitung
bDOWN01 = digitalRead(DOWN01); //Abfrage Eingang DOWN01, setzen Merker fuer Abarbeitung
bDOWN1 = digitalRead(DOWN1); //Abfrage Eingang DOWN1, setzen Merker fuer Abarbeitung
if (digitalRead(COUNTERRESET) == HIGH) {
poscount = 0;
if (bPosHold == HIGH) {
digitalWrite(ENA, LOW);
if (bDOWN01 == HIGH && !digitalRead(STPD)) { //wenn Down 0,1mm aktiv und Endschalter unten nicht belegt, dann
digitalWrite(ENA, LOW); //Stepper EIN
for (int index = 0; index <= steps_01; index = index + 1) //Anzahl der Schleifenwiederholungen/Schritte fuer 0,1mm Down
digitalWrite(DIR, HIGH); //langsame Einzelstep-Fahrt DOWN 0,1mm pro Tastendruck
digitalWrite(STP, HIGH);
delayMicroseconds(stepperspeed_l);
digitalWrite(STP, LOW);
while (digitalRead(DOWN01) == HIGH) { //Vereinzelung je Tastendruck DOWN, wait for DOWN01 == LOW
delay (100);
if (bPosHold == LOW) {
digitalWrite(ENA, HIGH); //Stepper AUS wenn Haltestrom nicht angewaehlt
poscount = poscount - 0.1;
if (bDOWN1 == HIGH && !digitalRead(STPD)) { //wenn Down 1mm aktiv und Endschalter unten nicht belegt, dann
for (int index = 0; index <= steps_1; index = index + 1) //Anzahl der Schleifenwiederholungen/Schritte fuer 1mm Down
digitalWrite(DIR, HIGH); //langsame Einzelstep-Fahrt DOWN 1mm pro Tastendruck
while ((digitalRead(DOWN1)) && !(digitalRead(STPD))) { //wait for DOWN1 == LOW oder Dauerfahrt DOWN nach Verzoegerung
delay (dec_continious);
display.fillRect(0, 0, 127, 63, WHITE); // OLED Displayanzeige FAST-DOWN
display.setTextColor(BLACK);
display.setCursor(10, 40);
display.println(“FAST-DOWN”);
display.display();
do {
digitalWrite(DIR, HIGH); //schnelle Dauerfahrt DOWN solange DOWN-Taste gedrueckt bleibt und Endschalter unten nicht betaetigt ist
delayMicroseconds(stepperspeed_h);
poscount_cont_down = poscount_cont_down + 1; //Inkrementieren Positionscounter Dauerfahrt DOWN
} while ((digitalRead(DOWN1)) && !(digitalRead(STPD)));
poscount_cont_down_mm = poscount_cont_down / steps_1; //Umrechnen Positionscounter Dauerfahrt DOWN in mm
poscount_cont_down = 0; //Reset Positionscounter Dauerfahrt DOWN
if (poscount_cont_down_mm != 0) { //Beschreiben Positionscounter global mit aktuellem Wert aus Dauerfahrt
poscount = ((poscount - 1) - poscount_cont_down_mm);
else { //Beschreiben Positionscounter global mit aktuellem Wert bei Einzelfahrt
poscount = poscount - 1;
if (bUP01 == HIGH) { //wenn Up 0,1mm aktiv, dann
for (int index = 0; index <= steps_01; index = index + 1) //Anzahl der Schleifenwiederholungen/Schritte fuer 0,1mm Up
digitalWrite(DIR, LOW); //langsame Einzelstep-Fahrt UP 0,1mm pro Tastendruck
while (digitalRead(UP01) == HIGH) { //Vereinzelung je Tastendruck UP, wait for UP01 == LOW
delay (100);
poscount = poscount + 0.1;
if (bUP1 == HIGH) { //wenn Up 1mm aktiv, dann
for (int index = 0; index <= steps_1; index = index + 1) //Anzahl der Schleifenwiederholungen/Schritte fuer 1mm Up
digitalWrite(DIR, LOW); //langsame Einzelstep-Fahrt UP 1mm pro Tastendruck
while (digitalRead(UP1) == HIGH) { //wait for UP1 == LOW oder Dauerfahrt UP nach Verzoegerung
display.fillRect(0, 0, 127, 63, WHITE); // OLED Displayanzeige FAST-UP
display.setCursor(25, 10);
display.println(“FAST-UP”);
display.display();
do {
digitalWrite(DIR, LOW); //schnelle Dauerfahrt UP solange UP-Taste gedrueckt bleibt
poscount_cont_up = poscount_cont_up + 1; //Inkrementieren Positionscounter Dauerfahrt UP
} while (digitalRead(UP1));
poscount_cont_up_mm = poscount_cont_up / steps_1; //Umrechnen Positionscounter Dauerfahrt UP in mm
poscount_cont_up = 0; //Reset Positionscounter Dauerfahrt UP
if (poscount_cont_up_mm != 0) { //Beschreiben Positionscounter global mit aktuellem Wert aus Dauerfahrt
poscount = ((poscount + 1) + poscount_cont_up_mm);
poscount = poscount + 1;
I’ve been trying to convert a few of my Arduino sketches into XOD as well, and honestly, it’s been more frustrating than I expected. The visual approach is great in theory, but when it comes to more complex logic or custom libraries, it quickly becomes limiting.
I get that XOD isn’t meant to fully replace Arduino code, but the lack of straightforward support for sketch conversion or better documentation around it makes the process feel like a guessing game. It’s a bit of a letdown, especially when you just want to get things working without completely rewriting everything from scratch.
Hope future updates make this smoother, because the concept has a lot of potential — it just needs more flexibility.
