Library needed for Motion Sensor HC-SR50x
Hello,
I’m at the beginning of the journey and I can’t figure out which mode to use to connect an HC-SR505 or HC-SR501.
From what I’ve seen, I can’t find any library for a motion sensor.
Can someone help me with a library for this sensor.
Info:
Thank you
Take a look at:
Thank you for the prompt reply and for the information.
It helps me a lot.
According to the specs you posted for the HC-SR505, it just requires a digital read. If output is high, motion has been detected; otherwise there is no motion. No library is required, just the built-in digital-read node.
Absolutely! The page I linked to describes how to use the sensor with XOD and provides a couple of example patches.
Ah. Sorry. I didn’t look into it & assumed you were recommending a different model of the sensor. It is not obvious that biomaker site would be a XOD reference, but the group has been using XOD & participating here in the past.
