Hello everybody,
I would like to know if anyone is also missing libraries in the “Project Browser” when updating the IDE to version 0.38.0.
After updating the IDE version for Windows from 0.31.0 to 0.38.0, I can no longer find the libraries “xod\bits” “xod\common-hardware”, “xod\core” etc. in the Project Browser.
The “welcome-to-xod” project is also missing.
See attached screen shot.
Can someone please help to solve this problem?
Thanks.
Select “switch workspace” to see what your current workspace path is. Either change to a new workspace, or browse to the workspace path to see if the __lib__ folder has any folders that start with xod. Deleting or renaming those folders after shutting down XOD should resolve your issue. Their existence indicates that you modified one of the built-in nodes and saved the changes. This results in problems when a XOD update tries to replace them.
Problem solved. Great job.
Thank you.
