Koadrobot/cast library
hello people, Im brand new to coding so please be patient.
I am trying to add Koadrobot/cast library and its not working…
Can someone please help me find a library to convert boolean to byte format.
Regards.
You can’t add the library, or you’ve added the library, but the node you want isn’t working?
You add libraries by going to XOD File > Add Library…
I wasn’t able to install the library, kept telling me the version was too old, but I found a library called koadrobot/kcast and that installed perfectly fine.
Thanks.
