I am new to XOD having just downloaded it.
Just doing a simple turn LED 13 on to test the connectivity etc before getting into deeper applications but having set the Port to D13 and Lum to 1 when I deploy up pops a Java Script Error message.
Have I missed something in either the setup or basic script causing this error? I am using a Uno 3 clone which uses a CH340G comms IC. It recognises the CH IC in the deployment menu so I am not convince this is the issue?
Any thoughts?
