Can anyone tell me if i can make in xod a button for example a pin analog in? for example, a button on analog A2 and? if yes, how do i put a tag? i tried put the A2 but it doesn’t work …
Hmmm…What happens when you use A2? I’m able to specify, but don’t have hardware out to test upload…
As a workaround, you should be able to reference analog pins using D# also. If your board has 16 digital pins, They will be labelled D0-D15. D16 will be the same as A0.
Yes, you are right, I tried to connect say A0-xodD14 and it works, just like A2-xodD16 and these are the pins … with only one I have a problem when I connect everything the same to A4-xodD18 or D2-xodD2 these pins it doesn’t work I don’t understand where the problem is, how much I see in the scheme should be ok or not?
