DS3231 node for programing SQW output
Does anyone know if there is a node for programing the DS3231 RTC SQW output, I need a temperature compensated 1HZ output from the DS3231, I am using it to control an analogue wooden clock.
This code would have to run to set up the RTC before the main loop, thanks in advance.
