Beep, bop! @dawreski, thank you for the research. The problem is that there’s a variety of DHT sensors (even two DHT-11’s can be different inside) and libraries for them.
What Arduino library do you use in Arduino IDE which gives you the successful readings show on the photo?
I’ve checked the code of dhtxx-read-raw used in XOD and there’s seemingly nothing that forces the start pulse to be as long as 50ms:
struct State {
bool reading;
{{ GENERATED_CODE }}
enum DhtStatus
DHT_OK = 0,
DHT_START_FAILED_1 = 1,
DHT_START_FAILED_2 = 2,
DHT_READ_TIMEOUT = 3,
DHT_CHECKSUM_FAILURE = 4,
unsigned long pulseInLength(uint8_t pin, bool state, unsigned long timeout) {
unsigned long startMicros = micros();
while (digitalRead(pin) == state) {
if (micros() - startMicros > timeout)
return 0;
return micros() - startMicros;
bool readByte(uint8_t port, uint8_t* out) {
// Collect 8 bits from datastream, return them interpreted
// as a byte. I.e. if 0000.0101 is sent, return decimal 5.
unsigned long pulseLength = 0;
uint8_t result = 0;
for (uint8_t i = 8; i--; ) {
// We enter this during the first start bit (low for 50uS) of the byte
if (pulseInLength(port, LOW, 70) == 0)
return false;
// Dataline will now stay high for 27 or 70 uS, depending on
// whether a 0 or a 1 is being sent, respectively.
pulseLength = pulseInLength(port, HIGH, 80);
if (pulseLength == 0)
return false;
if (pulseLength > 45)
result |= 1 << i; // set subsequent bit
*out = result;
return true;
DhtStatus readValues(uint8_t port, uint8_t* outData) {
// Stop reading request
digitalWrite(port, HIGH);
// DHT datasheet says host should keep line high 20-40us, then watch for
// sensor taking line low. That low should last 80us. Acknowledges "start
// read and report" command.
delayMicroseconds(30);
// Change Arduino pin to an input, to watch for the 80us low explained a
// moment ago.
pinMode(port, INPUT_PULLUP);
if (pulseInLength(port, LOW, 90) == 0)
return DHT_START_FAILED_1;
// After 80us low, the line should be taken high for 80us by the sensor.
// The low following that high is the start of the first bit of the forty
// to come. The method readByte() expects to be called with the system
// already into this low.
if (pulseInLength(port, HIGH, 90) == 0)
return DHT_START_FAILED_2;
// now ready for data reception... pick up the 5 bytes coming from
// the sensor
for (uint8_t i = 0; i < 5; i++)
if (!readByte(port, outData + i))
return DHT_READ_TIMEOUT;
// Restore pin to output duties
pinMode(port, OUTPUT);
// See if data received consistent with checksum received
uint8_t checkSum = outData[0] + outData[1] + outData[2] + outData[3];
if (outData[4] != checkSum)
return DHT_CHECKSUM_FAILURE;
return DHT_OK;
void enterIdleState(uint8_t port) {
void evaluate(Context ctx) {
State* state = getState(ctx);
uint8_t port = (uint8_t)getValue<input_PORT>(ctx);
if (state->reading) {
uint8_t data[5];
auto status = readValues(port, data);
if (status == DHT_OK) {
emitValue<output_D0>(ctx, data[0]);
emitValue<output_D1>(ctx, data[1]);
emitValue<output_D2>(ctx, data[2]);
emitValue<output_D3>(ctx, data[3]);
} else {
emitValue<output_ERR>(ctx, 1);
enterIdleState(port);
state->reading = false;
} else if (isInputDirty<input_UPD>(ctx)) {
// initiate request for data
digitalWrite(port, LOW);
// for request we should keep the line low for 18+ ms
setTimeout(ctx, 18);
state->reading = true;
} else {
A very careful comparison is required. However, it is a good idea to know what we should compare to
