Degree on lcd display
How can I print a ° (degree) on a 16x2 lcd display?
It depends on your display code page. On my display ° has hex code 99. So to output 13° C I bind the following to the L1 pin: 13\x99 C. The \x** sequence inserts raw character code at this point.
Note, however, if you want to print a 0-9, a-f, or A-F character right after the raw character, things get trickier because of rules of C++ parser. In that case, use a concat node to join the string ending with ° and its tail.
Thanks a lot for this hint. It works!
I used concat-4 instead of concat-3.
First String input is “Temperatur:”, 2nd is the temperature reading from the DHT11, 3rd is “\xDF” (my Display uses hex code DF for °) and 4th string is “C” (Celsius).
Glad to help.
BTW, you can press “…” on a topic bottom and press checkmark icon to mark the thread as “Solved” in just two clicks, without title editing.
!!! :grin::grin::grin:
