I must apologize, the update topic I read and then got side tracked and couldn’t find it again. I just wanted to say Xod is great! I do need a little advice, I work with numbers on the left of the decimal point using divide before an analog output, plus use LCD I2C for troubleshooting. After the update instead of having a number XX. it now reads XX.xx, so my question is how to get the LCD to not read the .xx when needed?
I think i may have mentioned this before, I love this IDE as you pick a node, connect it, upload to the controller and it happens. No hours on end scribbling code then not having the syntax right somewhere. Please keep up the great work!
LCD will default to converting numbers to a string with 2 decimal places. If you want something else, you need to convert it before feeding to LCD using format number node.
Try format-number with DIG set to zero.
Thanks gweimer and nkrkv for the replies. Multiplying an analog input I always had the numbers after the decimal point how ever I was surprised to see it with the count node.
g-p
