BMP280 to LCD 20x4
Hi,
Very New to XOD.
I am trying to get bmp 280 to read and display temp, pressure on LCD
but it will not keep reading “ERR” . Maybe to do with the format of the BMP280 output shows as number, I am guessing this is a INT.
Please Help,
Here’s an example of using the BMP280 with a 16x2 I2C LCD:
Screenshot 2020-08-09 at 13.09.16
I’ve used the barometer-thermometer node from my library: https://xod.io/libs/wayland/bmp280-barometer/
The format-number nodes convert the numeric output from the bmp280 to strings with a specified number of decimal places.
Here is the xodball:
bmp280-lcd.xodball (3.6 KB)
Hi Wayland,
Thanks for your assistance, I have managed to solve the issue,
The I2C address within the Adafruit_Seonsor Library show 0x77 mine is 0x76…
Hopefully others solve it too.
Really like this XOD but causing some headaches, now trying to solve if there is away to great a variable string output to the LCD based on a specific or greater than value from a sensor ?
If you know that would be great ?
Neil
Hi Neil,
You can use the greater, less and equal nodes to compare output from a sensor with a specified value. Here is an example you can run in the simulator:
The node at the top is a tweak-number to represent the output from a sensor. You can change the value of tweak-number at runtime. A watch node at the bottom displays the output.
