Control a speaker with a gyroscope
I’m trying to control a speaker with a gyroscope MPU6050. But this error occurs. Even if the boxes are not connected. Can anyone help find a solution?
The error text:
Begin compiling code for the board Arduino Uno :package:
C:\Users\81E4~1\AppData\Local\Temp\arduino-sketch-9E0510E37DE138C3C1D9472200D49B83\libraries\SoftwareSerial\SoftwareSerial.cpp.o (symbol from plugin): In function SoftwareSerial::read()': (.text+0x0): multiple definition of __vector_3’
C:\Users
\81E4~1\AppData\Local\Temp\arduino-sketch-9E0510E37DE138C3C1D9472200D49B83\sketch\xod_1609503300712_sketch.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
C:\Users\81E4~1\AppData\Local\Temp\arduino-sketch-9E0510E37DE138C3C1D9472200D49B83\libraries\SoftwareSerial\SoftwareSerial.cpp.o (symbol from plugin): In function SoftwareSerial::read()': (.text+0x0): multiple definition of __vector_4’
C:\Users\81E4~1\AppData\Local\Temp\arduino-sketch-9E0510E37DE138C3C1D9472200D49B83\sketch\xod_1609503300712_sketch.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
C
:\Users\81E4~1\AppData\Local\Temp\arduino-sketch-9E0510E37DE138C3C1D9472200D49B83\libraries\SoftwareSerial\SoftwareSerial.cpp.o (symbol from plugin): In function SoftwareSerial::read()': (.text+0x0): multiple definition of __vector_5’
Compilation failed
