Hello, sir. May I inquire about the systems available in XOD? In the following link Smart Garage Model by Blynk and XOD - Hackster.io, there is a tutorial on connecting XOD and Blynk using Bluetooth. However, when I attempted this with the latest version of Blynk, there is no longer an option to use Bluetooth; only the Wi-Fi option is available. Furthermore, when I tried using Wi-Fi in XOD with an ESP 32 module, I am still puzzled about how to connect the ESP 32 to Blynk. Is there a solution you could suggest, sir? Thank you.
