Cannot upload to Arduino Pro Mini in XOD 0.25.0
i keep getting the following error message when trying to upload.
normally, when using this board in Arduino IDE i need to set the CPU and the voltage/freq.
e.g. ATmega328P (3.3V, 8 MHz)
in version 0.24.0 i could and i had to set the correct device as well.
help very much appreciated. thanks.
Uploading compiled code to the board...
avrdude: invalid baud rate specified '{upload.speed}'
Error: exit status 1
Error during upload.
Upload tool exited with error
Command `C:\Users\tb\AppData\Local\Programs\XOD IDE\resources\arduino-cli.exe --config-file=C:\Users\tb\AppData\Local\Temp\arduino-clibE7z35\.cli-config.yml upload --fqbn arduino:avr:pro --port COM30 -t C:\Users\tb\AppData\Local\Temp\xod_temp_sketchbookVEzOUw\xod_1539808437696_sketch` failed with code 1
this is how it looks in Arduino.
000384
In the 0.25.0 we’ve significantly changed the mechanism for uploads. Obviously, now we have a bug for Arduino Pro. I confirm it. Created: https://github.com/xodio/xod/issues/1479
Will try to fix it quickly and release a hotfix. Thank you for reporting!
Fix is out, please update to 0.25.1
works like expected. nice.
thank you
