Hi guys, I’m trying to connect the very simple code I’ve done in XOD, there’s basically 1 node for a LED, linked with a circuit that I tested out also with Arduino Sketch, and there is working.
When I try to deploy the code it say that
the circuit is correct because I tested in Arduino and it’s working, also I tested every USB port and the message is the same.
What could be? Did anyone faced the same problem??
