Hi, XOD community!
Take a look at my new fun project done with IR sensors arrays, Arduino MKR ZERO and XOD:
Here is the barrel piano program: /gabbapeople/barrel-organ/
Libraries used:
Appreciate your feedback =)
Hi, XOD community!
Libraries used:
Hi gabbapeople
Thank you for replying to my message on Instructables. I appreciate it!
I have been working on a project for some time to develop a MIDI sequencer for Ableton Live using light dependent resistors on a turntable, activated by a vinyl record marked with different colours and tones to trigger MIDI events in Ableton. Then I saw your Barrel Piano, and the Octoliner board, and I realised this was a much better way to bring the project to life!
I am not an experienced programmer - I can do very basic Arduino stuff. XOD looked interesting as it is a visual IDE and your existing project gave me the idea to adapt your patch to operate my much simpler device - one Octoliner and an Arduino Leonardo connected to MacBook and Ableton.
I have done most of the XOD tutorials. I know I do not understand all of it. I tried to adapt your patches to make a simpler patch to run my project. The first problem I had was that the I2C address had changed so Octoliner was not responding - I fixed that. Now the XOD IDE says I am missing “MIDIUSB” library. I have the e/midi and e/usb-midi installed along with your code for the Barrel Piano.
Any advice you have would be really welcome Max! I hope to simply get this device up and running for now - simply passing MIDI messages to Ableton. Once I have this part working I can tweak the design. But for now I am stuck! Thank you for any help you can offer.
Best wishes from Glasgow, Scotland, Stay safe.
Mark
Hi, @markdawes
Can you copy here the full error log.
The MIDIUSB library should be in your XOD workspace in the ardulib folder. It should download automatically from github. Try to change your XOD workspace File->Switch workspace and flash the blank MIDIUSB patch to ensure that the library exist. Smth like this:
This node is in the e/midi-usb library in XOD inspector.
Thanks! I appreciate you taking the time to reply.
Thanks again.
Mark
Hi gabbapeople
I don’t think I understand any of the problems I have. XOD is also stating that I am missing the Arduino library “Wire.h”. I do have this on my Mac, but obviously XOD can’t find it. I also have the midi usb libraries in the correct folders. I have watched the dronebot videos and read all the User Guide (which I had not seen before). If you can help me in any way I would appreciate it!
M
That’s weird. What Mac OS version do you have? Try to reinstall XOD completely.
