XOD IDE installation, configuration, upgrade, and first compilation/upload problems.
There is a wild variety of PC configurations. Even more, are microcontroller board models. Chances something will go wrong with XOD in some combinations. Report such problems here, with all possible info: your OS, IDE version and flavor, screenshots and error log verbatim.
problem to XOD developers.
I have started by downloading Windows desktop version of XOD. Tried out the simulate exercise which OK. Second I tried to change the clock speed to 0.1. Did Deploy - simulate and got a red line with error message. I have uninstalled XOD and reinstalled it twice and I am still getting the same error in compiling message before even changing the interval setting.
I’m totally stuck. cam anyone help?
