Добрый день уважаемые!
мне 37 лет и я вообще не бум-бум в программировании.
купил дочке (8 лет) набор планета XOD (Планета XOD: построй свою базу на Марсе! / Амперка - не реклама)
и вместе мы начали постигать премудрости XOD.
В принципе все шло отлично до главы 16, где учат создавать новые ноды. дошли до этой главы и затык! не полуяается как в брошюрке! А товарищи из амперки помогать не спешат((.
В принципе, я нашел материал тут:
Создание нод для XOD в XOD — XOD)%2C%20%D1%87%D1%82%D0%BE%D0%B1%D1%8B%20%D1%81%D0%B4%D0%B5%D0%BB%D0%B0%D1%82%D1%8C%20%D1%8D%D1%82%D0%BE.
и повторил его. Но в брошюрке то пишут по-другому… Короче, помогите кто чем может, а то я что-то туплю…
It is a LOT harder to translate pictures than text.
How far have you gotten trying to create your own patch/node? The picture you included does not show any other patch tabs beside “main” at the top. XOD uses “patch” and “node” interchangeably…they mean the same thing in XOD. (or maybe “patch” describes the code for a “node”)
If you double-click on any of the nodes (like “clock”), it will open a new tab and show you how that node was built. To create your own node, you are just building a new node like all the built-in nodes that can be included in your “main” patch. Above you have input pins in your “main” patch; this is NOT how it should be done. Those input/output pins are only used on other patches you create to include in other patches. It looks like you skipped the first step on the “Creating nodes for XOD in XOD” website you posted: File → New Patch, which requires you to create a name for your new patch. This will open a new tab at the top of your workspace so you can switch between your new node and “main”.
dear gweimer!
Thanks for answering!
we know how to use logical operators. use some hardware nodes. such as led pot and others.
now we can make our nodes. but, it is not clear why in the book on “main” terminal nodes
it looks like they are creating a “panic” node in the picture.
I will check this assumption and unsubscribe!
ps sorry for my english
Ah…looks like the picture has an error. If they are creating a “panic” node, then it should NOT be called “main”. A new patch needs to be created called “panic”. The “panic” node can then be used from “main” (or other patches).
