Hello, xoders!
We’ve released a new version of XOD IDE: v0.16.1. Nothing huge and great has been done, that’s a bugfix release. Nevertheless, it makes XOD better. Here is the changelog:
Features and enhancements
- [ide] Patch crafting optimized. Performance gain is ~35%
Bug fixes
- [core] Fix code generation for C++ nodes local to the current project: no more
@symbols in the code - [ide] Trigger library search when a library name is pasted from the clipboard
- [ide] Fix regression of macOS auto-update failure introduced in 0.16.0
- [ide] Fix patch board break when trying to drag-n-drop the patch node on itself or adjacent UI elements
- [ide] Fix embedded code editor overflow past the window boundaries when source code is too long
- [ide] Handle network connection problems gracefully while authorization and library publishing
- [ide] Escape regular expression symbols while searching for a node (thanks @awgrover)
- [ide] In the account pane, send credentials on Enter press
