Hey everyone,
I’m at a point where I’m stuck and i’m not nearly skilled enough in C++ to use an existing Canbus library and implement it in XOD.
I’m willing to pay someone for their time to help collaborate with me and build a Node(s) for the use of the MCP2515 Chip.
the node needs to be able to do the following.
- read can bus
- Filter specific Can Bus IDs
- Set Baud Rate for can bus
- Adjustable Hardware config based on if there is an 8mhz or 16mhz MCP2515.
- Node can output a string or numbers for each Byte.
Does not need to be able to Write to Can Bus.
Would be nice if looked something like this
