Ubuntu mega upload issue
Had a similar issue last year and was able to resolve it. This time not so much. I searched this community and did some of the older reply suggestions. I really love the XOD IDE.
I have the Mega attached to a robotic arm which works as it was programmed to do about a year ago. I had a Niece that wanted to see how it worked and do something different. I can not upload to the Mega, I can upload to the Uno and the Nano but not the Mega2560.
mega defaults to /Dev/ttys9.
The Uno defaults to /Dev/ttyACM0(Arduino(www.arduino.cc))
This is the message
     User configuration file does not exist or is not a regular file, skipping
     Using Port                    : /dev/ttyS9
     Using Programmer              : wiring
     Overriding Baud Rate          : 115200
avrdude: ser_open(): can’t set attributes for device “/dev/ttyS9”: Inappropriate ioctl for device
ioctl(“TIOCMGET”): Bad file descriptor
avrdude: ser_drain(): select(): Bad file descriptor
avrdude: ser_send(): write error: Bad file descriptor
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): select(): Bad file descriptor
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
Error: exit status 1
Error during upload.
Upload failed
I think I got it figured out, I have 3 Mega 2560 controllers only 1 will communicate.I even tried on a windows computer and the same result. These are fairly old controllers I will have to trouble shoot the boards or get new ones. Thought I would pass it on.
thanks
