Transpiling Error message
I receive the following message…
· Transpiling…
Error
UNEXPECTED_ERROR {“message”:“Can’t find the patch in the project with specified path: “””"}
Please find attached my patch…
RW_SD_card.xodball (78.8 KB)
Any help appreciated.
Which version of XOD you are using???
Yesterday i updated current new version (XOD IDE Setup 0.21.0) and same transpiling error occurred in my code also, so i downloaded older version (XOD IDE Setup 0.19.2) and my code started working. I hope it help.
Thanks,
I was using the version prior the the new version that you made available today.
I will re-build the patch tonight with the new version of XOD IDE without using any of the NODES from my original patch and try again.
I will post the results.
Thanks for your help.
Hello! Thanks for reporting. Looks like a serious issue. Will try to fix it ASAP https://github.com/xodio/xod/issues/1304
Hi!
While we are fixing this bug, here is a quick workaround: delete existing concat node and create a new one.
Fix is released in v0.21.2
Thanks again for reporting!
Hi,
Sorry for the delayed response.
Thank you for your time and effort, If I have time this evening I will start from the beginning and build the patch again.
Thanks once again .
The “recreate concat node” workaround was for v0.21.1 and before.
Now you can update to 0.21.2 and your original patch will just work, no rebuilding is required on your part :wink:
