I’m new here, so apologize if I’m not asking the right question or in the right area…
Is there a node/library for the TCA9548A i2C multiplexer??
I’m trying to recreate a project in XOD and can find all components except this one…
Looking at this example
you don’t actually need a node / library.
you could try to use the standard i2c nodes (begin-transmission + write-byte) to send the signals you require to toggle the outputs.
Give it a go, good luck.
you probably want to follow this XOD guide as a work through
