I would like to use a 13.56Mhz RC522 RFID Module (reader/writer module) with XOD. However, I cannot find any hardware node that falls into that category.
Is there already a Library containing this node ?
In alternative how do I create one?
Can someone help ?
Davide
cesars
January 13, 2019, 2:00pm
2
I can try something quick with read / write, would you prove it?
ps: here trying, after changing the library, I already have some results
Test library …
It is not finished …
It is not documented …
If you wish you can download and try it, it only works in read mode
link MFRC522 add as cesars/mfrc522
cesars
January 13, 2019, 8:23pm
3
pinouts
Pins SPI UNO Mega2560 Leonardo
1 (NSS) SAD (SS) 10 53 10
2 SCK 13 52 SCK1
3 MOSI 11 51 MOSI1
4 MISO 12 50 MISO1
5 IRQ * * *
6 GND GND GND GND
7 RST 5 ? Reset
8 +3.3V (VCC) 3V3 3V3 3.3V
Thanks a lot cesars
I am new to Arduino and I am experimenting.
Tomorrow I will get the RFID reader writer and I will test your node
Best
Hi Cesar. I am having problems with mfrc522. during the simulation process. this is what appears #include SPI.h
What should I do . Thank you very much
cesars
September 10, 2019, 1:33pm
7
Hi, it’s a common mistake that many users are making. Not all nodes can be simulated, the node includes an external library not supported by the simulator. Use upload and debug.
I think there is a warning or an indication of using debug. @nkrkv
thanks cesar can already be simulated
hi do you have new update for this library?
I need write to nfc 522
regards
cesars
May 19, 2021, 9:52am
10
Hello, next update will be on this rc522 , library MRFC522 is obsolete.
ok, tanks: whan you will think it will be?
cesars
May 21, 2021, 12:18am
12
I haven’t used XOD for a long time, but I’ll see if I can update it in a few days
Puedo ayudarlo si le parece bien @cesars
cesars
June 6, 2021, 7:49pm
14
We will see it in the next few days, thank you
