tobias
July 31, 2018, 1:31pm
#1
Hi guys,
i need to integrate a specific RTC into my programming. This is communicating via SPI.
Does anybody have a clue how to start in XOD/C++
Is it possible to implement SPI communication into a xod patch? Can the Standard SPI Arduino Library be integrated somehow.
Website: http://www.microcrystal.com/index.php/products/real-time-clocks
Datasheet: http://www.microcrystal.com/images/Product-Documentation/02_Oscillator &_RTC_Modules/01_Datasheet/RV-2123-C2.pdf
Manual: http://www.microcrystal.com/images/Product
Documentation/02_Oscillator &_RTC_Modules/02_Application_Manual/RV-2123-C2_App-Manual.pdf
can someone pint me to the next steps?
Best Tobias
Have you looked at the builtin RTC nodes? Even if they don’t work with your device, they will give you a starting point for what the code should look like.
tobias
July 31, 2018, 1:43pm
#3
Thank you for your reply.
The problem is the built in uses I2C instead of SPI - i would copy the rest of the node but would like to set up the SPI communication with the RTC.
