Tried 2 different picos.
Submitted the “001-hello” example.
I get errors. Are the picos not supported? I just assumed they were, since you can select them in the xod menu.
I do remember the first time I plugged it in, it XOD wanted to download some additional stuff and I remember xod saying that it was deprecated. So now I have 2 version of the pico to select from. But none of the work. I get the same error. Seems one is the updated version, the other is the old deprecated version.
I can upload examples created with Arduino IDE fine when. But doesnt work when trying to upload stuff in XOD.
I can also get the onboard LED to light up when I program it via Thonny.
This is with the first “Raspberry Pico” model selected (either the deprecated version or not). I get this error:
Begin compiling code for the board Raspberry Pi Pico ![]()
C:\Users\TRJ1\xod_packages_\packages\arduino\hardware\mbed\3.3.0\cores\arduino\main.cpp:52:1: internal compiler error: in output_macinfo_op, at dwarf2out.c:26881
Please submit a full bug report,
with preprocessed source if appropriate.
See https://gcc.gnu.org/bugs/ for instructions.
C:\Users\TRJ1\xod_packages_\packages\arduino\hardware\mbed\3.3.0\cores\arduino\timer.cpp:37:1: internal compiler error: in output_macinfo_op, at dwarf2out.c:26881
Compilation failed
If I then select the other Raspberry pico selected.
: internal compiler error: in decl_attributes, at attribs.c:453
C:\Users\TRJ1\xod_packages_\packages\arduino\hardware\mbed_rp2040\4.1.3\cores\arduino\api\Stream.cpp:321:1: internal compiler error: in output_macinfo_op, at dwarf2out.c:26881
C:\Users\TRJ1\xod_packages_\packages\arduino\hardware\mbed_rp2040\4.1.3\cores\arduino\Interrupts.cpp:88:1: internal compiler error: in output_macinfo_op, at dwarf2out.c:26881
C:\Users\TRJ1\xod_packages_\packages\arduino\hardware\mbed_rp2040\4.1.3\cores\arduino\Tone.cpp:65:2: internal compiler error: in output_macinfo_op, at dwarf2out.c:26881
Compilation failed
