Putting in a Request for a Gas sensor (mq-135)
I would like to put in a request for a gas sensor node specifically mq-135 to be built and added to the xod platform. The mq-135 belongs to the family of gas sensors capable of reading a wide variety of gases and the most preferred sensor used by makers and developers in air quality projects.
This is a website containing information pertaining to this sensor.
Hi Atia,
I’ve got the following mq sensors: mq2 (methane, butane, LPG, smoke), mq3 (ethanol, smoke) and mq7 (carbon monoxide).
mq_sensors
I’m planning to make nodes for each of them over the next few days, and I can make a node for the mq135 as well. If you want to try making a node yourself, take a look at the following guide:
https://xod.io/docs/guide/analog-sensor-node/
It’s just an analog or digital sensor (depending on how you configure it. You don’t need a custom node. Just use digital-read or analog-read.
I breathe on the sensor.
ztKwH94LBG
This is very helpful thank you. In the future I definitely will try to build my own nodes and share them as well.
Ok I had the same thought but I was not really sure about that but thank you for the heads-up. I will give it a try with other kinds of gases as well.
