Problem with 'Multiply' node disappearing
I have just started to use XOD and I am doing the welcome project.
I have reached 10maths and the problem is the ‘Multiply’ node has changed
into a box with words in it.
How do I get it back to the node ?
Sammysquirrel
Most likely, you have added a label to it (displays a new name, but still functions the same), or you have created your own multiply node.
If inspector shows anything besides “xod/core/multiply”, you just have the wrong node. If it you have the right node & no label, then you have over-written the default node. You will need to go to your workspace folder and delete the __lib__\xod folder.
