NEO6M GPS LIBRARY "gps-receiver"
Hi volks
I want to use the library of @ivanmason but…
  • you can’t say wich port at the board should be used by the neo6mv2-device for RX & TX
  • in the library - “main” node there is an exampel, but its not possible no compile it
Can anyone help with the lib?
THX
hi volks
the example in main was done for a mega using the second rx tx port.
you need to change xod/uart-1 node for the rx tx port on your board
hope this helps you
Thanks @ivanmason I get it! Just change the Uart-1 againt soft-uart and it was easy going!
