I had do dinosalvioni/hwlibrary/rf433receive node baseo on bradzilla84/433mhz-rcswitch
it works fine in “stand alone program” but when i put it in more big complex software (as example bitrex/xod-menu-system) it start but dont work (interrupt dont receive siglal or similar effect)
I suspect it is something related to interrupt management
How XOD operate with interrupts?
there’s a node for use easy interrupts signal? (as example interrupt number -> interrupt pulse that start and run “over the main program”)
Any comment and workaround is welcome.
The best thing would be a tutorial on the interrupt’s use
I Use Arduino Mega
Thanks a lot
