Hi guys! ![]()
I am working on a project where I need to interface a DS18B20 temperature sensor with an Arduino using XOD. I’ve followed a few tutorials and have managed to get some basic readings, but I am facing issue where the readings sometimes spike to unrealistic values (e.g., -127°C).
Here are the steps I’ve taken so far:
- Connected the DS18B20 to the Arduino with the appropriate pull-up resistor on the data line.
- Used the XOD DS18B20 node to read the temperature values.
- Added a watch node to monitor the readings in real-time.
- Despite these steps, I still get occasional incorrect readings. I suspect it might be a problem with my wiring or perhaps a glitch in the code. Has anyone else experienced similar issues? If so, how did you resolve them? Any advice on debugging techniques or code adjustments in XOD would be greatly appreciated.
I also check this : https://forum.xod.io/t/temperature-sensor-am2302-dht22-not-workingcp But I have not found any solution.
Thanks! ![]()
