I can do this with C in Arduino IDE I’m trying to find a way to stop a counter when the number reaches a certain number!
Count increments when count-INC gets a pulse. You can stop the count by running that pulse through a gate node and only enable gate when count is less than your Max value. Since the output of count will affect input of count, you will need a defer node to loop back up in your patch.
So one of the things great things about writing C is you can control bits and port pins very easy, there isn’t a node that will pulse out a Boolean value unless I’m missing something here. I’m trying to momentarily reset a pin on a CD4017!
I’m using the digital-write node, I only need to pull the port pin high for a couple of milli second and then reset it low again.
You can try connecting delay-ACT to value for digital-write, then set delay-T to 0.002. In theory, it should work, but I don’t know how well delay will handle that small a value.
So I tried it and it worked for 5 minutes then it stopped working I tried a new Xod window and it wouldn’t work anymore even on another board. I have no idea at this point I’m going back to Arduino IDE
