Hello Forum!
When i started with Arduino serveral years ago it was to struggle with code-writing but now with XOD its is great!
However I ran into a problem. I was using a LoLin NodeMCU V3 as hardware but as I am to use a 5V relay and also 1-wire sensors DS18B20 with quite long cables i changed over to a Arduino UNO that is running 5V signal voltage instead of 3.3V.
The question I now have is the WiFi connection!
On the NodeMCU i used “xod-dev/esp8266-mcu/connect” and it works great.
To the UNO I had a Adafruit CC3000 Wifi connected. But as that was not supported in XOD I purchased a ESP8266 ESP-01S card. Thinking of the “Welcome to XOD- exercise - 112-stand alone internet” that mentioning that this could be a usable way.
I thought just to change ut the node in my program to “xod-dev/esp8266/connect” instead of the one for the mcu-board.
But how to wire the ESP8266? I cannot find a XOD example. Is it OK to use the RX/TX pins on the Arduino or should i use other pins to keep them clear? What is the node expecting?
I also believe I need to lower the signal voltage to 3.3V with resistors, not a problem or can I connect it directly as in this example from the web? : https://hackster.imgix.net/uploads/attachments/533124/circuit_jRmiSWSOwQ.jpg?auto=compress%2Cformat&w=1280&h=960&fit=max
Hope you all understand my questions. Thanx in behalf!
