Hello colleagues!
I apologize for my bad English, but I use Google translator.
I ask the help of experts. I have an M269 LCD “Clover Display Ltd.” It is connected with 4 contacts - power and I2C.
Symbols and signs on the display are arranged as follows:
character layout
Information is transmitted to the LCD in six-way code words W1 — W6, in this correspondence:
match characters and codewords
W1 is responsible for initializing and contrasting the LCD, W2 is for displaying five large and seven small characters, W3 is for displaying nine medium and three small characters, W4 and W5 are for turning on and blinking mnemonic characters, labels, displaying decimal points and underscoring large and middle characters. The code word W6 carries service information and is not displayed on the LCD screen.
The character generator for the numbers and letters of the Latin alphabet turned out to be the same as the indicators with the HD44780 controller.
Through Arduino IDE the sketch works well:
#include <Wire.h>
void setup() {
Wire.begin();
byte v = 0;
void loop()
Wire.beginTransmission(59); // начало передачи устройству с адресом “44” (0x3B)
//Word 1
Wire.write(byte(0x80));
Wire.write(byte(0x34));
Wire.write(byte(0x0c));
Wire.write(byte(0x06));
Wire.write(byte(0x35));
Wire.write(byte(0xff));
Wire.write(byte(0x9d));
Wire.write(byte(0x80));// 80
Wire.write(byte(0x03)); //03
Wire.write(byte(0x04));// переворот контраст и пр
Wire.write(byte(0x08)); // переворот контраст и пр
Wire.endTransmission();
delay (200);
//Word 2
Wire.write(byte(0x40));
Wire.write(byte(0xCD)); //1 ряд 1 символ
Wire.write(byte(0x43));// 1 ряд 2 символ
Wire.write(byte(0x3A));// 1 ряд 3 символ
Wire.write(byte(0x34));// 1 ряд 4 символ
Wire.write(byte(0x34));// 1 ряд 5 символ
Wire.write(byte(0x32));// малый верхний ряд 1 символ
Wire.write(byte(0x35));// малый верхний ряд 2 символ
Wire.write(byte(0x00));// малый верхний ряд 3 символ
Wire.write(byte(0xCD));// малый верхний ряд 4 символ
Wire.write(byte(0x43));// малый верхний ряд 5 символ
Wire.write(byte(55));//малый нижний ряд 1 символ
Wire.write(byte(55));// малый нижний ряд 2 символ
Wire.write(byte(0x20));
delay (150);
//Word 3
Wire.write(byte(0xc0));
Wire.write(byte(49)); //2 ряд 1 символ
Wire.write(byte(50));//2 ряд 2 символ
Wire.write(byte(51));//2 ряд 3 символ
Wire.write(byte(49)); //2 ряд 4 символ
Wire.write(byte(0x32)); //2 ряд 7 символ
Wire.write(byte(0x33));//2 ряд 5 символ
Wire.write(byte(0x34)); //2 ряд 6 символ
Wire.write(byte(0x35)); //малый нижний ряд 3 символ
Wire.write(byte(0x36)); //малый нижний ряд 4 символ
Wire.write(byte(0x37)); //малый нижний ряд 5 символ
Wire.write(byte(0x38)); //2 ряд 8 символ
Wire.write(byte(0x39)); //2 ряд 9 символ
delay (150);
//Word 4
Wire.write(byte(0x40)); //мигание нижнего ряда 80 вместо 40
Wire.write(byte(0x00)); // мигае левый набор символов
/* 01 стакан
02 палка
03 палка со стаканом
04 дворник
05 дворник и пустой стакан
06 палка и дворник
07 палка стакан дворник
08 “ofset”
09 “ofset” и стакан
10 “MEAS”
11 “MEAS” и стакан
12 “MEAS” палка*/
Wire.write(byte(0x00)); //mts err ATC
/00 пусто
01 ATC
02 MTC
03 ATC+ MTC
04ERR
05 ERR+ATC/
Wire.write(byte(0x00)); //setup и точка “реле 3”,было 08
Wire.write(byte(0x00));//было 01
/01 setup
02 точка в “реле 3”
10 Redy
redy setup
redy setup./
Wire.write(byte(0x00)); //ready rel3 кружек 3 реле и точка 4рел //было 08
/*HOLD
REL3
REL30
Wire.write(byte(0x00)); // точки 1 ряда
Wire.write(byte(0x00)); // точки 2 ряда
Wire.write(byte(0x00)); // тире в верхнем правом углу//было 20
delay (150);
Wire.beginTransmission(59);// этот модуль на экран не выводится
Wire.write(byte(0x60));
Wire.write(byte(v)); //замените подбором
delay (150);
//Word 6
Wire.write(byte(0x00)); // разные режимы работы дисплея,было 03
Wire.write(byte(0x40)); //если установить 80 то дисплей мигает
delay (150);
v++;
if (v>255) v=0;
I tried to run this LCD in the XOD as follows:
How to correctly initialize this display and start transmitting bytes in code words in the XOD?
Thank you for any good advice!
