How to fix the problem?
WARNING: library Servo claims to run on avr, sam, samd, nrf52, stm32f4 architecture(s) and may be incompatible with your current board which runs on renesas_uno architecture(s).
In file included from C:\Users\kalpa\AppData\Local\Temp\xod_temp_sketchbookHxw3f4\xod_1690544362622_sketch\xod_1690544362622_sketch.ino:985:0:
C:\Users\kalpa\AppData\Local\Temp\xod_temp_sketchbookHxw3f4\libraries\Servo\src/Servo.h:73:2: error: #error “This library only supports boards with an AVR, SAM, SAMD, NRF52 or STM32F4 processor.”
Compilation failed
I dont know much about XOD and Arduino and dont know how to fix it.
I fixed it.ooooooooooooooooooooooooooooooooooooooooooooooooooooo
Other people might run into the same problem. Please share how you fixed it.
