Hi, did anyone manage to find a wy to use bluetooth comms in XOD?
I want to be able to receive letters and number from my phone via bluetooth and can’t get it to work as much as I try.
I tried the example supplied with gabbapeople’s libray but doesn’t work and I’m out of ideas.
Module work in Arduono IDE so there’s no hardware issue.
I did.
Use soft-uart node:
- google your board’s name and “software serial pins” to find out which pins are suitable for establishing software UART connection
- remember that module’s RX and TX pins are meant to be wired to Arduino’s (“node’s”) TX and RX pins respectively
- as you’re familiar with Arduino IDE, try SoftwareSerialExample first to choose proper baud rate
When you’re done with connection, use xod/uart/is-available and xod/uart/read-bytes to receive bytes and then use them as you wish, for example pulse-on-sequence node may be helpful.
I’ve just made one more example using HC-05 bluetooth communication, and in addition to the steps described above want to emphasize that is-available node’s default UPD pin value is Never, should be changed to Continuously
Here’s my implementation of the byte commands processing ferret.mp4_snapshot_01.23.741|690x388
If you read in Russian and use Telegram, you may learn more on the context of the problem being solved in a short video annotation here: Telegram: Contact @automate_courses and in the series of posts above in the channel.
