Hi there
If I try to add a graphics node I can’t compile the patch, if I removed it no problem to compile. I got that error massage:
Begin compiling code for the board Arduino Due (Programming Port)
C:\Users\MDHL\AppData\Local\Temp\xod_temp_sketchbookBExvuP\xod_1599591879378_sketch\xod_1599591879378_sketch.ino:1837:5: error: in-class initialization of static data member ‘const unsigned char xod::xod__graphics__temperature_16x16_rgb::Node::icon []’ of incomplete type
C:\Users\MDHL\AppData\Local\Temp\xod_temp_sketchbookBExvuP\xod_1599591879378_sketch\xod_1599591879378_sketch.ino: In member function ‘void xod::xod__graphics__temperature_16x16_rgb::Node::evaluate(xod::xod__graphics__temperature_16x16_rgb::Node::Context)’:
C:\Users\MDHL\AppData\Local\Temp\xod_temp_sketchbookBExvuP\xod_1599591879378_sketch\xod_1599591879378_sketch.ino:1912:66: error: invalid conversion from ‘const unsigned char*’ to ‘uint8_t* {aka unsigned char*}’ [-fpermissive]
state->myBitmap = new (state->mem) Bitmap(icon, 1, 16, 16);
In file included from C:\Users\MDHL\AppData\Local\Temp\xod_temp_sketchbookBExvuP\xod_1599591879378_sketch\xod_1599591879378_sketch.ino:1081:0:
C:\Users\MDHL\AppData\Local\Temp\xod_temp_sketchbookBExvuP\libraries\Graphics/Bitmap.h:11:5: error: initializing argument 1 of ‘Bitmap::Bitmap(uint8_t*, uint8_t, uint16_t, uint16_t, uint16_t)’ [-fpermissive]
Bitmap(uint8_t* newBuffer = nullptr, uint8_t newColorDepth = 0, uint16_t newWidth = 0, uint16_t newHeight = 0, uint16_t newKeyColor = 0x0000) {
I’m using already the xod version 0.35.0
