Compilation Error - Sending Text to a PC From Arduino
I’d like to send data over the USB-serial interface from an Arduino Uno/Nano to my PC. I found the uart-usb block and implemented what I thought would print over USB to the PC, but I got an error.
Here is the error I get.
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227707999_sketch/xod_1557227707999_sketch.ino:1806:22: error: request for member 'begin' in '* state->xod::xod__uart__uart_usb::State::uart', which is of non-class type 'int'
         state->uart->begin();
Error: exit status 1
Compilation failed.
Compilation failed
Command `/opt/XOD\ IDE/resources/arduino-cli --config-file=/tmp/arduino-cliOaFk8V/.cli-config.yml compile --fqbn arduino:avr:uno --verbose /tmp/xod_temp_sketchbookh5AAy6/xod_1557227707999_sketch` failed with code 1
There’s more to the stack trace, but I didn’t want to flood this post with the whole trace. I can post it if needed. I’m so new to XOD I don’t know if my patch is even close to right, and the only examples I’ve found online are for serial communication between two Arduinos. I’m running version 0.29.1 of the XOD IDE.
After Compiling sketch..., there are some first lines of code that marks the error, is that?
I have tried and I have no error, but I can not send data, the truth is that I have not used Uart
Here’s the full stack trace:
Begin compiling code for the board Arduino/Genuino Uno 📦
Using board 'uno' from platform in folder: /home/jwright/xod/__packages__/packages/arduino/hardware/avr/1.6.21
Using core 'arduino' from platform in folder: /home/jwright/xod/__packages__/packages/arduino/hardware/avr/1.6.21
Detecting libraries used...
/home/jwright/xod/__packages__/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jwright/xod/__packages__/packages/arduino/hardware/avr/1.6.21/cores/arduino -I/home/jwright/xod/__packages__/packages/arduino/hardware/avr/1.6.21/variants/standard /tmp/arduino-sketch-E9F2EAFBFC762880BDD0722ACEDBD130/sketch/xod_1557227849531_sketch.ino.cpp -o /dev/null
Generating function prototypes...
/home/jwright/xod/__packages__/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jwright/xod/__packages__/packages/arduino/hardware/avr/1.6.21/cores/arduino -I/home/jwright/xod/__packages__/packages/arduino/hardware/avr/1.6.21/variants/standard /tmp/arduino-sketch-E9F2EAFBFC762880BDD0722ACEDBD130/sketch/xod_1557227849531_sketch.ino.cpp -o /tmp/arduino-sketch-E9F2EAFBFC762880BDD0722ACEDBD130/preproc/ctags_target_for_gcc_minus_e.cpp
/home/jwright/xod/__packages__/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino-sketch-E9F2EAFBFC762880BDD0722ACEDBD130/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/jwright/xod/__packages__/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jwright/xod/__packages__/packages/arduino/hardware/avr/1.6.21/cores/arduino -I/home/jwright/xod/__packages__/packages/arduino/hardware/avr/1.6.21/variants/standard /tmp/arduino-sketch-E9F2EAFBFC762880BDD0722ACEDBD130/sketch/xod_1557227849531_sketch.ino.cpp -o /tmp/arduino-sketch-E9F2EAFBFC762880BDD0722ACEDBD130/sketch/xod_1557227849531_sketch.ino.cpp.o
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino: In constructor 'xod::xod__debug__tweak_string_16::State::State()':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1153:24: error: array used as initializer
     State() : view(buff) {}
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino: At global scope:
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1368:5: error: 'Serial_' does not name a type
     Serial_ _serial;
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1373:21: error: expected ')' before 'serial'
     UsbUart(Serial_ serial, long baud = 9600)
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1406:5: error: 'Serial_' does not name a type
     Serial_* toUsbSerial() {
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino: In member function 'virtual bool xod::xod__uart__uart_usb::UsbUart::available()':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1383:22: error: '_serial' was not declared in this scope
         return (bool)_serial.available();
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino: In member function 'virtual bool xod::xod__uart__uart_usb::UsbUart::writeByte(uint8_t)':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1387:22: error: '_serial' was not declared in this scope
         return (bool)_serial.write(byte);
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino: In member function 'virtual bool xod::xod__uart__uart_usb::UsbUart::readByte(uint8_t*)':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1391:20: error: '_serial' was not declared in this scope
         int data = _serial.read();
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino: In member function 'virtual void xod::xod__uart__uart_usb::UsbUart::begin()':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1413:5: error: '_serial' was not declared in this scope
     _serial.begin(getBaudRate());
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino: In member function 'virtual void xod::xod__uart__uart_usb::UsbUart::end()':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1417:5: error: '_serial' was not declared in this scope
     _serial.end();
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino: In member function 'virtual void xod::xod__uart__uart_usb::UsbUart::flush()':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1420:5: error: '_serial' was not declared in this scope
     _serial.flush();
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1428:26: error: 'Serial_' was not declared in this scope
 struct ChooseUartWrapper<Serial_> {
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1428:33: error: template argument 1 is invalid
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1433:49: error: 'SerialUSB' was not declared in this scope
     uint8_t mem[sizeof(ChooseUartWrapper<typeof SerialUSB>::UartT)];
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1433:58: error: template argument 1 is invalid
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1434:30: error: 'SerialUSB' was not declared in this scope
     ChooseUartWrapper<typeof SerialUSB>::UartT* uart;
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1434:39: error: template argument 1 is invalid
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1434:42: error: expected ';' at end of member declaration
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino: In function 'void xod::xod__uart__uart_usb::evaluate(xod::xod__uart__uart_usb::Context)':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1533:35: error: 'struct xod::xod__uart__uart_usb::State' has no member named 'mem'
         state->uart = new (state->mem) ChooseUartWrapper<typeof SerialUSB>::UartT(SerialUSB, (uint32_t)getValue<input_BAUD>(ctx));
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1533:65: error: 'SerialUSB' was not declared in this scope
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1533:74: error: template argument 1 is invalid
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1534:48: error: no matching function for call to 'emitValue(xod::xod__uart__uart_usb::ContextObject*&, int*&)'
         emitValue<output_UART>(ctx, state->uart);
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1534:48: note: candidate is:
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1508:33: note: template<class OutputT> void xod::xod__uart__uart_usb::emitValue(xod::xod__uart__uart_usb::Context, typename xod::xod__uart__uart_usb::ValueType<OutputT>::T)
 template<typename OutputT> void emitValue(Context ctx, typename ValueType<OutputT>::T val) {
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1508:33: note:   template argument deduction/substitution failed:
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1534:48: note:   cannot convert 'state->xod::xod__uart__uart_usb::State::uart' (type 'int*') to type 'xod::xod__uart__uart_usb::ValueType<xod::xod__uart__uart_usb::output_UART>::T {aka xod::Uart*}'
/tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch/xod_1557227849531_sketch.ino:1538:22: error: request for member 'begin' in '* state->xod::xod__uart__uart_usb::State::uart', which is of non-class type 'int'
Compilation failed.
Compilation failed
Command `/opt/XOD\ IDE/resources/arduino-cli --config-file=/tmp/arduino-cliOaFk8V/.cli-config.yml compile --fqbn arduino:avr:uno --verbose /tmp/xod_temp_sketchbookh5AAy6/xod_1557227849531_sketch` failed with code 1
Your mistake starts here. :point_up_2:
I think it uses Linux, in W10, I do not have that error.
Change tweak-string-16 by constant-string or just put “,” in concat, to see if the error disappears.
@cesars Thanks for the help. Your suggestion eliminated that tweak error, but more still remain. I forgot to mention that I’m on Ubuntu 18.04.
/home/jwright/xod/__packages__/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jwright/xod/__packages__/packages/arduino/hardware/avr/1.6.21/cores/arduino -I/home/jwright/xod/__packages__/packages/arduino/hardware/avr/1.6.21/variants/standard /tmp/arduino-sketch-474461764F7EBBAC95E11CD6EB649512/sketch/xod_1557248877405_sketch.ino.cpp -o /tmp/arduino-sketch-474461764F7EBBAC95E11CD6EB649512/sketch/xod_1557248877405_sketch.ino.cpp.o
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1281:5: error: 'Serial_' does not name a type
     Serial_ _serial;
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1286:21: error: expected ')' before 'serial'
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1319:5: error: 'Serial_' does not name a type
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino: In member function 'virtual bool xod::xod__uart__uart_usb::UsbUart::available()':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1296:22: error: '_serial' was not declared in this scope
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino: In member function 'virtual bool xod::xod__uart__uart_usb::UsbUart::writeByte(uint8_t)':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1300:22: error: '_serial' was not declared in this scope
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino: In member function 'virtual bool xod::xod__uart__uart_usb::UsbUart::readByte(uint8_t*)':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1304:20: error: '_serial' was not declared in this scope
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino: In member function 'virtual void xod::xod__uart__uart_usb::UsbUart::begin()':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1326:5: error: '_serial' was not declared in this scope
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino: In member function 'virtual void xod::xod__uart__uart_usb::UsbUart::end()':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1330:5: error: '_serial' was not declared in this scope
     _serial.end();
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino: In member function 'virtual void xod::xod__uart__uart_usb::UsbUart::flush()':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1333:5: error: '_serial' was not declared in this scope
     _serial.flush();
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino: At global scope:
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1341:26: error: 'Serial_' was not declared in this scope
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1341:33: error: template argument 1 is invalid
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1346:49: error: 'SerialUSB' was not declared in this scope
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1346:58: error: template argument 1 is invalid
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1347:30: error: 'SerialUSB' was not declared in this scope
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1347:39: error: template argument 1 is invalid
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1347:42: error: expected ';' at end of member declaration
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino: In function 'void xod::xod__uart__uart_usb::evaluate(xod::xod__uart__uart_usb::Context)':
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1446:35: error: 'struct xod::xod__uart__uart_usb::State' has no member named 'mem'
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1446:65: error: 'SerialUSB' was not declared in this scope
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1446:74: error: template argument 1 is invalid
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1447:48: error: no matching function for call to 'emitValue(xod::xod__uart__uart_usb::ContextObject*&, int*&)'
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1447:48: note: candidate is:
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1421:33: note: template<class OutputT> void xod::xod__uart__uart_usb::emitValue(xod::xod__uart__uart_usb::Context, typename xod::xod__uart__uart_usb::ValueType<OutputT>::T)
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1421:33: note:   template argument deduction/substitution failed:
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1447:48: note:   cannot convert 'state->xod::xod__uart__uart_usb::State::uart' (type 'int*') to type 'xod::xod__uart__uart_usb::ValueType<xod::xod__uart__uart_usb::output_UART>::T {aka xod::Uart*}'
/tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch/xod_1557248877405_sketch.ino:1451:22: error: request for member 'begin' in '* state->xod::xod__uart__uart_usb::State::uart', which is of non-class type 'int'
Compilation failed.
Compilation failed
Command `/opt/XOD\ IDE/resources/arduino-cli --config-file=/tmp/arduino-cliOaFk8V/.cli-config.yml compile --fqbn arduino:avr:uno --verbose /tmp/xod_temp_sketchbookh5AAy6/xod_1557248877405_sketch` failed with code 1
I just noticed that if I replace the uart-usb block with the uart block, I don’t get an error.
Ups, I was testing in UART, I thought you had renamed it, I also have the error with UART-USB
Ok, interesting. It happens in Windows too then. I wonder if I should open an issue on GitHub.
yes, i think this is an issue
I submitted an issue on GitHub for this: https://github.com/xodio/xod/issues/1775
Yeah, this is so misguiding that it should be considered a bug.
The uart-usb node represents a USB serial on the boards having a dedicated CDC interface (like Leonardo or Micro). For Uno and Nano the interface is shared with UART #0. So, if you would use uart-0 instead of uart-usb, all should work fine for you.
