ESP8266 wont connect to WIFI
Hey,
I am trying to use ESP8266 to connect to WIFI using “example-get-ips” program that delivered with XOD by default. Any time I try to connect I get error on the KICK node inside the ES8266 node… I cant get a log or the text of the error anywhere.
I am using this module which can also be seperated, I tried to use it with and without the adapter board and at different baud rates but no luck…
Thanks!
