Dear friends tell me what’s wrong? ESP8266 MQTT publish after loading data is transmitted only 1-2 times and then silence although it should be sent at intervals of 6 seconds.![1|690x351]
try connecting the sensors in cascade and not all together to the clock, that is…TICK > UPD… OK > UPD… OK > UPD …
Thank you for your advice! Now it is sent almost normally but for about 1-2 hours then the broker does not publish again only after the ESP is rebooted
try doing the same with ACK> INIT and what happens
you can also include a throttle node between them and remove the clock
Thanks! All night the device worked from 6 PM to 7 am and hung! Tell me is it possible to reboot the device if it stops sending messages to MQTT topics
I don’t have much experience, it only occurs to me to send OK to INIT, and you could also reconnect an ANY and send a pulse every so often.
place a flip-flop on the OK output and send the signal to an LED to see if it stops working when it stops.
Dear Xoders,
i have the same problem with Subscribe.
When i send each, two till three seconds a value to the Subscribe node, then its run permanent.
But when i send a value very fast, then after 3-4 received Values Subscribe stops working.
I tested it with diverent keep alive times on Broker side but nothing changed.
Status:
- Wemos D1 Mini (Connected to Router permanent)
- MQTT Client is showing on Mosquitto Broker on Scan with Topic permanent.
- Only Publish works permanent
- When Subscribe received fast values, publish and sub. stops working after a view received values.
- I used a clock on the update port on the subscribe node. Nothing works here.
Question:
It could be possible that the buffer is runing full?
Give it a problem with keep alive settings?
Do we need a Pingrequest node when we use Subscribe to hold the connection open?
Thank you in advance
Chris
