Outputs’ names and lines not corresponding each other
It is for all nodes not only this one
When I tested it the bug appeared on some nodes. While everything is okay on other. Would you check whether xod/bits/number-to-u32
renders correctly or not on your machine?
Yes, this node is shown correctly, but this bug happens to almost all nodes…
