Hi volks,
I try to upload this sketch to arduino due, but I get an error within compiling. I also try to upload it with arduino IDE but it doesen’t work. I have noticed that, if I delete the soft-uart node it’s possibel to upload the sketch! But I need soft-uart.
Maybe someone now what to do with that kind of error.
C:\Users\MDHL\AppData\Local\Temp\arduino-sketch-0F26D9368F0525880D2A84CB11E9238E\sketch\xod_1598642169960_sketch.ino.cpp.o: In function xod::xod__uart__soft_uart::SoftwareUart::begin()': C:\Users\MDHL\AppData\Local\Temp\xod_temp_sketchbookRygL7P\xod_1598642169960_sketch/xod_1598642169960_sketch.ino:1304: undefined reference to SoftwareSerial::begin(long)’
C:\Users\MDHL\AppData\Local\Temp\arduino-sketch-0F26D9368F0525880D2A84CB11E9238E\sketch\xod_1598642169960_sketch.ino.cpp.o: In function xod::xod__uart__soft_uart::SoftwareUart::end()': C:\Users\MDHL\AppData\Local\Temp\xod_temp_sketchbookRygL7P\xod_1598642169960_sketch/xod_1598642169960_sketch.ino:1308: undefined reference to SoftwareSerial::end()’
C:\Users\MDHL\AppData\Local\Temp\arduino-sketch-0F26D9368F0525880D2A84CB11E9238E\sketch\xod_1598642169960_sketch.ino.cpp.o: In function SoftwareUart': C:\Users\MDHL \AppData\Local\Temp\xod_temp_sketchbookRygL7P\xod_1598642169960_sketch/xod_1598642169960_sketch.ino:1264: undefined reference to SoftwareSerial::SoftwareSerial(unsigned char, unsigned char, bool)’
C:\Users\MDHL\AppData\Local\Temp\arduino-sketch-0F26D9368F0525880D2A84CB11E9238E\sketch\xod_1598642169960_sketch.ino.cpp.o: In function xod::xod__uart__soft_uart::SoftwareUart::available()': C:\Users\MDHL\AppData\Local\Temp\xod_temp_sketchbookRygL7P\xod_1598642169960_sketch/xod_1598642169960_sketch.ino:1274: undefined reference to SoftwareSerial::available()’
C:\Users\MDHL\AppData\Local\Temp\arduino-sketch-0F26D9368F0525880D2A84CB11E9238E\sketch\xod_1598642169960_sketch.ino.cpp.o: In function xod::xod__uart__soft_uart::SoftwareUart::writeByte(unsigned char)': C:\Users\MDHL\AppData\Local\Temp\xod_temp_sketchbookRygL7P\xod_1598642169960_sketch/xod_1598642169960_sketch.ino:1278: undefined reference to SoftwareSerial::write(unsigned char)’
C:\Users\MDHL\AppData\Local\Temp\arduino-sketch-0F26D9368F0525880D2A84CB11E9238E\sketch\xod_1598642169960_sketch.ino.cpp.o: In function xod::xod__uart__soft_uart::SoftwareUart::readByte(unsigned char*)': C:\Users\MDHL\AppData\Local\Temp\xod_temp_sketchbookRygL7P\xod_1598642169960_sketch/xod_1598642169960_sketch.ino:1282: undefined reference to SoftwareSerial::read()’
C:\Users\MDHL\AppData\Local\Temp\arduino-sketch-0F26D9368F0525880D2A84CB11E9238E\sketch\xod_1598642169960_sketch.ino.cpp.o: In function xod::xod__uart__soft_uart::SoftwareUart::flush()': C:\Users\MDHL\AppData\Local\Temp\xod_temp_sketchbookRygL7P\xod_1598642169960_sketch/xod_1598642169960_sketch.ino:1311: undefined reference to SoftwareSerial::flush
Multiple libraries were found for “TinyGPS++.h”
Used: C:\Users\MDHL\AppData\Local\Temp\xod_temp_sketchbookRygL7P\libraries\TinyGPSPlus
Using library TinyGPSPlus at version 1.0.2 in folder: C:\Users\MDHL\AppData\Local\Temp\xod_temp_sketchbookRygL7P\libraries\TinyGPSPlus
Error: exit status 1
Compilation failed.
Compilation failed
Arduino IDE error:
