Hello XOD community I’m looking for either a patch or node to drive an A4988 Stepper Motor driver. Anyone have such a thing? An example would be great. Appreciate your help.
Have you checked to see if any of these work? https://xod.io/libs/?q=stepper
To use the libraries, go into XOD and select File > Add Library, then type in the library you want to add to your XOD install.
Another one that might work is
AccelStepper
