Is it possible to read a 12v square wave with analog input or digital read if i run it through a voltage divider on an Arduino? I’m not sure what the frequency range would be.
It should work, unless the frequency of the wave is too high, in which case Arduino will miss some of the transitions.
Thank you. I’ll give it a try.
