The info message indication that I should wait does not get cleared. Task manager shows three instances if XOD with no significant CPU time. Systems are both Win 10 64 bit on four core CPUs. 0.25.2 installed okay.
Hello, I have running 0.25.3 in W10 64bit with no problems.
Download of XOD manually
Thank you. That did the trick. Does the installation detect the flavor of the OS – as in 32 vs. 64 bit? Looks like the installer itself is a 32 bit process which I suppose makes sense.
Gene
XOD is only supported on Win 64-bit.
