XOD development setup
I was hoping to address the arduino-cli version, but am having issues getting a XOD development environment set up completely. Is there a place that has thorough dev documentation? Covering things like setting up environment variables, 3rd party downloads, logging options, etc?
so far I have figured out:
  • There was a very clear message about adding arduino-cli to the PATH or creating an environment variable for it, so I did that.
  • I see you have nvm specified for v10
  • I’m currently running into errors in my dev Electron app when I try to “Upload to Arduino…”, it says
ERROR undefined does not have a method named “split”
ps: I’m on OSX
Do you get this error right on the opening of the Upload to Arduino popup? At first sight, it looks like there is no aruino-cli found or it has another version. We are using an old alpha build version of arduino-cli: http://downloads.arduino.cc/PR/arduino-cli/arduino-cli-25-PR91-osx.zip
We have to update it to the latest version, but so far it has not reached the hands.
Another way to provide arduino-cli to the desktop IDE is to copy the arduino-cli right inside xod-client-electron and rename it to just arduino-cli like on the screenshot:
Try to download the one mentioned above and ensure that everything works.
Also, you can run tests for the arduino-cli JS wrapper with the same name. Run tests from the root of the repository: yarn test --scope arduino-cli && yarn test-func --scope arduino-cli. Do not forget to run yarn && yarn build before.
After that, if you want to update arduino-cli to the latest one, try to update it and run tests again. It might fail. Perhaps even with the same error. In this case you have to fix arduino-cli package. Then you can run tests and test uploading, updating indexes and etc manually.
If everything works fine, we’ll be happy if you make a pull request then :slight_smile:
:bulb: That totally makes sense, that’s exactly what unit tests are for!
Is there a debugging/logging framework that you use, or have considered incorporating? Or a IDE you use for debugging/stepping?
such as:
