How can Implement the DFRobot mlx90614 with my project in xod?
I was using Wayland mlx90614 node library but when compiling and uploading I get errors:
Begin compiling code for the board Arduino Uno
C:\Users\nico\AppData\Local\Temp\xod_temp_sketchbookjA84sS\xod_1714224135410_sketch\xod_1714224135410_sketch.ino: In member function ‘void xod::wayland__mlx90614__mlx90614::Node::evaluate(xod::wayland__mlx90614__mlx90614::Node::Context)’:
C:\Users\nico\AppData\Local\Temp\xod_temp_sketchbookjA84sS\xod_1714224135410_sketch\xod_1714224135410_sketch.ino:1675:61: error: no matching function for call to ‘Adafruit_MLX90614::Adafruit_MLX90614(unsigned char&)’
Type sensor = new (mem) Adafruit_MLX90614(address);
In file included from C:\Users\nico\AppData\Local\Temp\xod_temp_sketchbookjA84sS\xod_1714224135410_sketch\xod_1714224135410_sketch.ino:1498:0:
C:\Users\nico\AppData\Local\Temp\xod_temp_sketchbookjA84sS\libraries\Adafruit_MLX90614_Library/Adafruit_MLX90614.h:46:7: note: candidate: Adafruit_MLX90614::Adafruit_MLX90614()
class Adafruit_MLX90614 {
C:\Users\nico\AppData\Local\Temp\xod_temp_sketchbookjA84sS\libraries\Adafruit_MLX90614_Library/Adafruit_MLX90614.h:46:7: note: candidate expects 0 arguments, 1 provided
C:\Users\nico\AppData\Local\Temp\xod_temp_sketchbookjA84sS\libraries\Adafruit_MLX90614_Library/Adafruit_MLX90614.h:46:7: note: candidate: constexpr Adafruit_MLX90614::Adafruit_MLX90614(const Adafruit_MLX90614&)
C:\Users\nico\AppData\Local\Temp\xod_temp_sketchbookjA84sS\libraries\Adafruit_MLX90614_Library/Adafruit_MLX90614.h:46:7: note: no known conversion for argument 1 from ‘unsigned char’ to ‘const Adafruit_MLX90614&’
It appears that my XOD library was broken by changes to the underlying Arduino library. I’ve now fixed my XOD library - please install the new version and let me know how you get on. I don’t have one of the sensors, so I haven’t been able to test my library. However, the example patch does now compile!
Thank you for the feedback. We still getting the following errors when compiling.
C:\Users\nico\AppData\Local\Temp\ccAmLedg.ltrans0.ltrans.o: In function read16': C:\Users\nico\AppData\Local\Temp\xod_temp_sketchbookulrYa2\libraries\Adafruit_MLX90614_Library/Adafruit_MLX90614.cpp:134: undefined reference to Adafruit_I2CDevice::write_then_read(unsigned char const*, unsigned int, unsigned char*, unsigned int, bool)’
C:\Users\nico\AppData\Local\Temp\ccAmLedg.ltrans0.ltrans.o: In function begin': C:\Users\nico\AppData\Local\Temp\xod_temp_sketchbookulrYa2\libraries\Adafruit_MLX90614_Library/Adafruit_MLX90614.cpp:36: undefined reference to Adafruit_I2CDevice::Adafruit_I2CDevice(unsigned char, TwoWire*)’
C:\Users\nico\AppData\Local\Temp\xod_temp_sketchbookulrYa2\libraries\Adafruit_MLX90614_Library/Adafruit_MLX90614.cpp:37
: undefined reference to `Adafruit_I2CDevice::begin(bool)
OK, so the Arduino library for the MLX90614 requires the Adafruit BusIO library. I already had the BusIO installed, so compilation worked for me. I’ve now modified my XOD library so that it will automatically install the BusIO library.
