A bit of extra information about the problem uploading patches to the SAMD21 board embedded in the Odyssey Blue SBC… (i) the Arduino IDE works for uploading sketches to the SAMD21, or an Arduino UNO board attached to a USB port. (ii) XOD will happily upload a patch to the externally attached UNO. (iii) The same XOD patch appears to be uploaded successfully to the internal SAMD21, but the code (simple LED flashing) doesn’t run.
Here’s the report from the XOD uploader:
Performing 1200-bps touch reset on serial port COM8
Waiting for upload port…
“C:\Users\ODYSSEY\xod_packages_\packages\Seeeduino\tools\bossac\1.7.0-arduino3/bossac.exe” -i -d --port=COM7 -U true -i -e -w -v “C:\Users\ODYSSEY\AppData\Local\Temp\xod_temp_sketchbookPCpO5O\xod_1608409132050_sketch\build\Seeeduino.samd.zero/xod_1608409132050_sketch.ino.bin” -R
Set binary mode
readWord(addr=0)=0x20007ffc
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v2.0 [Arduino:XYZ] Oct 12 2018 18:20:29
chipId=0x10010005
Connected at 921600 baud
Atmel SMART device 0x10010005 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Oct 12 2018 18:20:29
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security : false
Boot Flash : true
readWord(addr=0x40000834)=0x7000a
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 0.854 seconds
Write 38068 bytes to flash (595 pages)
write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x1000)
[=== ] 10% (64/595 pages)
writeBuffer(scr_addr=0x20005000, dst_addr=0x3000, size=0x1000)
[====== ] 21% (128/595 pages)
writeBuffer(scr_addr=0x20005000, dst_addr=0x4000, size=0x1000)
[========= ] 32% (192/595 pages)
writeBuffer(scr_addr=0x20005000, dst_addr=0x5000, size=0x1000)
[============ ] 43% (256/595 pages)
writeBuffer(scr_addr=0x20005000, dst_addr=0x6000, size=0x1000)
[================ ] 53% (320/595 pages)
writeBuffer(scr_addr=0x20005000, dst_addr=0x7000, size=0x1000)
[=================== ] 64% (384/595 pages)
writeBuffer(scr_addr=0x20005000, dst_addr=0x8000, size=0x1000)
[====================== ] 75% (448/595 pages)
writeBuffer(scr_addr=0x20005000, dst_addr=0x9000, size=0x1000)
[========================= ] 86% (512/595 pages)
writeBuffer(scr_addr=0x20005000, dst_addr=0xa000, size=0x1000)
[============================= ] 96% (576/595 pages)
write(addr=0x20005000,size=0x4c0)
writeBuffer(scr_addr=0x20005000, dst_addr=0xb000, size=0x4c0)
[==============================] 100% (595/595 pages)
done in 0.327 seconds
Verify 38068 bytes of flash with checksum.
checksumBuffer(start_addr=0x2000, size=0x1000) = 9f00
checksumBuffer(start_addr=0x3000, size=0x1000) = 9f6a
checksumBuffer(start_addr=0x4000, size=0x1000) = fe7c
checksumBuffer(start_addr=0x5000, size=0x1000) = 1f34
checksumBuffer(start_addr=0x6000, size=0x1000) = e2ba
checksumBuffer(start_addr=0x7000, size=0x1000) = 9655
checksumBuffer(start_addr=0x8000, size=0x1000) = ae1a
checksumBuffer(start_addr=0x9000, size=0x1000) = ced7
checksumBuffer(start_addr=0xa000, size=0x1000) = 3a7c
checksumBuffer(start_addr=0xb000, size=0x4b4) = b97a
Verify successful
done in 0.029 seconds
CPU reset.
writeWord(addr=0xe000ed0c,value=0x5fa0004)
=== Done ===
